1985 Monte Carlo SS from the ground up.....
I originally wanted to go with a mustang gt hydroboost which I have in my nova and it works great. But trying to keep it simple and the cost low as I can.. so car came with a single diaphragm booster and a disc/drum master.. after reading a bunch of threads went with a dual booster and the caprice M/C cuz of the direct bolt on and bore size needed for the disc/disc brakes.. will see how it works.. I still believe the hydroboost with the bracket angle on there is close to working
Reactions: Tony1968
Brought out the genders and wheel wells out from hiding..
Mounted the fenders, wheel wells, headlight buckets and the front bumper...
Finally got around and ordered 2” wheel adapters for the rear.. I had 2 different wheels on the rear, a 15” steel crager and 17” GTO spare that I use in case I get a flat in my nova..
Took the seats out of hiding and decided to clean them.. front/backs are in good shape with no rips just a bit dirty, of coarse the driver side is always the dirtiest
