Yes the guy told me it has around 540. He is also giving me everything I need from transmission to motor mounts.
Tuggy24g said:Hey I have a 396 that I bought on ebay for 2800 that came with everything. When I mean everything I mean everything. It came all the way to nuts and bolts to put it right into the engine bay. Well since 5th gen El Caminos did not have big block in them I was wondering how hard will it be to get one in there and what will I need to add to get one to work properly?
megaladon6 said:if you want really good handling, go with a small block. if you're showing off and occasionally at the drag strip-you have the BBC, you might as well use it.
as to transmission? a properly built 200r4 will hold up to BB power (especially the 396-not the most powerful motor) and the th-350 will easily take it. you do not need a th40, they're really a truck transmission and overkill for a car.
do you know how the engine was built? what cam, compression, etc? or if it's just stock, what car it's from? some of them were REALLY wimpy.
