I have the Edelbrock 1406 carburetor mounted on the stock manifold with a adapter will the transmission work without the lock up for now ? What will happen if I keep the orginal distributor on ?Yep, TH200C. You will also need to wire up a toggle switch or get a lock up kit. The TV cable needs some tension at idle and full pull at full throttle. Get one of the Ebay Olds V8 cheap HEI's. I picked up one from Skip White Performance. It was surprisingly well built for a $40 distributor. You want 38 to 40 base and mechanical and maximum vacuum advance off a manifold source. I would have gone with something other than the Edelbrock carb. Hopefully you didn't get one that can't be tuned no matter what is done.
Will this lock up kit work? Do you have a link to the distributor I would need thanks for all the informationAs long as you not driving on the highway, you can live without lock up. As said, you time it at the base 20 degrees, it will stay at 20 degrees, nearly 40 degrees less than you should have at part throttle.
