EL CAMINO 1987 in electrical hell!
vpmac
vpmac
16
Fayetteville Ga.
#1
All I wanted to do was install Autometer gauges in my El Camino. Pulled the dash cluster found the wires for each gauge and dash lights after some help here on the forum. The numbered diagram was a great help. Many thanks. So with the cluster out I now have no power to the accessory side of the ignition. No radio, no heater blower. I checked all fuses, and the fuse links down by the starter. They are all good. Is there a connection between the gauge cluster connector and the ignition that I don't know about. There is a wire on the diagram that says Ing/ acc coming from the gauge cluster, could this need to be connected to something? Could a wire from the gauge cluster go back to the ignition switch? Does anyone know a good auto electrical guy that does house calls in the Atlanta area?
Thanks
Mac
vpmac
vpmac
16
Fayetteville Ga.
#2
I found it!! Believe it or not, the ground wire to the blower fan was not making good contact. I did not know that ground also is the ground for you wipers. Duh! Still figuring out why the radio is not getting power. Peogress..
Mac
Daca214
Daca214
374
386
Jupiter, FL
#3
Thats good info to know. Thanks for the update.
