What is the rear end out of? I have an 84ss with original rear end and I want to convert the brake from drum to calipers any info would be greatly appreciated. ThanksHeres the rear end im work n with did the camaro ls1 rear disc now just gotta get the posi unit installed and gearsView attachment 40474
Are the spindles orginal? If not may I ask what kind are they?Do n the z51 corvette in front 13.49 rotors i think it was in front got the brakets from kore3. Running ls1 caliperView attachment 40476
There is a possibility you have an 8.5"...look at the bottom of the housing at the 4 & 8 o clock positions. Then look at the chart...What is the rear end out of? I have an 84ss with original rear end and I want to convert the brake from drum to calipers any info would be greatly appreciated. Thanks
