LolLeave the column shifter in place and flip your passenger's mind when you put it in gear with the floor shifter...
Only issue was the alternator sat up high but luckily i had the cowl hood and had to trim a bit of the under side not much and i am run a th350 transVery clean looking swap. No clearance issues with the truck front accessories? What trans are you running?
Would like to get a 12 bolt from a 64-67 chevelle or a grand national but i would settle for a 3.73 posi from a SS mine wasnt factory posi car plus when i bought itvthe rear end was toast has a really tall one leggerMan I havent been on here for a while and you have made alot of progress.. That is pretty good work you have done to it so far. What did you have in mind for your rear end?
