The ok 1 thing I forgot to mention about the advance auto deal os the highest discount per order is 50 off so thats why you have to do 2. I have done this several times for my hubs, calipers, dba rotors and other parts.pepboys normally offers 25 to 35 off as well but I have found some parts are cheaper at advance.
I see you haven't put them springs in yet! LOL! Such a not fun job. I rented a compressor to do mine and what a p.o.s. it was. I wound up putting the spring on the bottom arm and used a 2 in aluminum block with a hole in the center and used the fingers inside the spring and compressed the hell outta of it. Then I used 2 ratcheting strap 1on each side to give it a a better chance of not killin me. I also used a 4x4 block of wood with a 1in hole drilled thru so I could put the compressor bolt head inside of so I could place it on top of the jack. I still had to use 2 more jacks on the bushing points and the weight of the car to install the springs. My 1st time in years doing this but it seemed harder this time around. Now I did use 1in lower springs so maybe the spring weight fought me? But its done. I truely cant see how it can be done anyother way. I did buy a new compressor with my deposit only because I have a feeling I will be installing 2in or even coil overs later.
But wow amazing how some sanding and spray paint can make things look so much better.
The rear is that a 7.5 or 8.5 10bolt?
