I drove my friends Caddy CTS with the V-6 and 5 speed stick. LOADS of power and a dream to work through the gears. I think that would fit our cars without much trouble.
I saw some where, that they were using the engine mounts out of a 4cyl canyon to do a nova?? They also had an adapter plate for a 700r4. Not too shabby 8) . I think a EcoTec swap would be really different, and it would make a good autocross car.
That is impressive power, especially torque wise at 2400 rpm. The 3.6 would be just as cool, especially with a turbo. I am super or turbo charging my v6 Challenger after the warranty is up. Adds 140 rwhp to the 3.5 plus 100 ft/lbs of torque with 10 lbs of boost.
295 TQ at 2,400 is ok but if you don't have great torque you can make up for it with gearing which the new 6 speed should do well. With an old 3 speed like many of these cars came with it wouldn't be a lightning bolt. My car with me in it weighed 3,840 on the scale. Fuel economy and engine longevity comes when off boost. The 4 cylinder needs boost to move the car moderately. A turbo V6 would be a better choice in that it naturally makes more torque and lower in the rpm range on & off boost. It would easily move the car moderately or easily with normal traffic again off boost which in fact my turbo 3.8 V6 does.
It will still be better than what the majority of these cars originally came with. Nobody even measures power output at that low of an rpm range but with a torque peak at 2400 it will have enough power even lower.
The big thing is the power curve, big engines have a wide curve while small engines have narrow (peaky) curves. Big cars like G bodies need a wide power curve for street driving, a narrow band may be okay for racing but not for normal driving where the engine usually runs at low RPMs most of the time. With turbo engines boost kicks in at higher RPMs where the engine needs it.
