2 part epoxy for wheel wells
chevymalibu283
Apr 4, 2013
58
37
Anyone know what epoxy filler is needed to fill holes or cracks in the plastic wheel wells for our cars?
any info would be great
thanks everyone,
Kevin
ssn696
Living in the Past
5,549
6,683
Permanent Temporary
I used JB Weld (fast set). No data yet on durability on the car. I put painter's tape closely around the crack and stuffed the epoxy into the crack, then clamped together. Next morning, I used a razor blade to trim and clean up what squeeze out. When cut, the epoxy is no longer black but a grey color.
565bbchevy
9,618
12,699
Michigan
I used JB Weld's Plasticweld epoxy when I filled all the unused holes in my wheelwells and it worked great, I sanded the areas and painted the entire wheel wells with a satin black paint made for plastics.
ssiron
Mar 28, 2010
50
8
Sweetwater, Texas
thanks everyone,
Kevin
Going by a recent experience I would recommend some 3m panel bonding adhesive. This stuff works great you need to clean the area as well as possible and open the joint enought to get the material well into it. The working time on is product is about an hour and sets in 4. Full strength in 24 hours. The down side is you need an applicator for the product. It's in a twin cartridge arrangement, it will mix thru the tip but you can put a quanity on a surface if you remove the tip. After it cures you can sand drill, just about anything you need to do to it.
Frank
chevymalibu283
Apr 4, 2013
58
37
Frank
Thanks guys appreciate the info. I will look into these options.
