200m to turbo350 swap
mastersativa
25
I have an 85 cutlass with a 200m and now a 403 in it from a trans am, i have the turbo 350 that came with the motor and am wondering if i can swap it right in or do i need to modify or change my cross member?
Should be a straight swap.
T
Yeah thanks bud, once i had more time i searched on here and found out its no problem swap, i never had one with a metric Trans, but now I'm schooled, thanks again.
No prob.. Tons of info here, soak it up.
T
You'll need the Th350 dipstick and tube.
The kickdown cable and bracket won't interchange either.
RockAuto.com has new cables for like $15.
You may need a new speedo gear too depending on what gears your car has and what gears that t/a had, otherwise your speedometer won't work correctly.
I do have the cable and bracket, i just don't have the dipstick tube and stick. Guess I'm going junkyard hopping.
Probably easier to order a new one from Jegs or Summit as vehicles with TH-350 aren't real prevalent in junkyards these days.
I did this swap, great upgrade but I wish i had a 2004r put in instead. 3 speeds limit gear choices for a daily driver if you care about gas mileage at all.
