200r4 transmission to flexplate space
spongbob
287
215
66
Ok just picked up a 200r4 trans came with a torque converter while looking it over I noticed the converter went on the input and meshed with the pump it seems somewhat deep into the bell houseing I would say an inch from the mounting surface not having done a lot of transitions...I thought someone here can could say where or not there is that much oposite space from. The engine mounting surface to the face of the flexplate maybe 7/8" or I can find out when I get it in place does this seem OK? Motor is old chevy 307 with small flexplate for streight bolt starter
Sounds right to me, they go in quite a bit. How many times did it "fall" into place? What I mean is that you'll feel it slip into different stages of being fully installed.
I had about 4 washers worth of space, I tightened the flexplate to the converter and it puked trans fluid on the floor, pulled the converter out too far. Use washers to take up most of the space.
Reactions: Sweet_Johnny
Yeah I guess im just worrying I did find a sbc block picture showing the flexplate to block looks ti be 7/8 so probly use hard fender washers thanks I feel better about starting now ....just not today...ño that's not my converter...lol
When you install the transmission, push the converter all the way into the trans and then pull it towards the flexplate about 1/8-3/16". If you need a washer to space it off the flexplate to keep that location then use one. Do not keep the converter all the way into the pump and do not pull it more than 3/16" out of the transmission.
