Considering that it has 778lb/in springs in the rear that is a lot of compression given the change from static ride height. The general rule of thumb with street tires is that you want them to roll over onto the should to make the most of the tire. These tires are (practically) load rated like an SUV tire.
This car hates tires.
that is alot of spring for the rear so I looked it up and now I am confused....what a found was 359 lbs up front with the 778 lbs in the rear which is backwards of the rates we used for circle tack and road course cars so Dodge must have some tricks up their sleeves for the suspension.
I see if I waited 30 seconds I would not have had to look it up.... 🤔
