2019 Challenger Widebooty HellKitty (she's giving me the meatsweats...)
I'm curious about the weight and sound differences.
In general terms, as I understand it, high carbon stainless steel typically is about 2.5 times heavier than aluminum. So the math is there - I'll try to weigh both systems for science (but, chances are I won't ;))
Material density is another consideration as it relates to resonant frequency and sound absorption/transmission. Again, my understanding, is that aluminum will absorb more sound (act less like a high frequency tuning fork) than steel... resulting in a softer less tinny tone both through the wall and out the tail pipe.
Grab a coffee and a some LSD:
And here's a little something about noise absorption using perforated materials... which are enhanced with a packing material or the like:
So, when I was in the field (low voltage residential construction management), as a tech, I had a couple of sayings I used to throw around: "everything works on paper" and "Engineering hands out square wheels. I pound out the corners so it actually rolls." Now, I hand out the square wheels. In the garage, you have the luxury of rounding the corners as you go.
  • Wow
Anecdotal evidence:
Tips showed up... at 4.4kg they weigh almost as much as the whole rest of the exhaust.
Yeah, I am thinking of making a set now. Sigh.
Supercharged111
4,934
7,717
Colorado Springs, CO
2 weeks later:
images
YAAAAY WEIGHT SAVINGS!!!!!!
Mean Rob Lowe GIF by Parks and Recreation
If they were half the weight, how were you planning to mate those to the pipe?
Oh, I am still using them. Going to weld a length of 3" pipe to the back and slip them into the mufflers.
cannoli GIF
If I find i don't like them or if the weight bothers me that much - I will just use them on the TBSS because it has dual exhaust and a single tip.
