PETA and Global Warming fanatics got the Turtle Wax Ice taken off the selves.... 😕
The Challenger are only a few hundred pounds heavier than our G bodies. So if these are pigs, our G bodies aren't far behind. The V6 RWD are actually right around the same weight as my fully loaded Brougham interior Cutlass. Also similar size as my 88 Cutlass but more similar to my 70S, probably because it was styled after the original Challenger.
FALSE! My 88 Cutlass Supreme Classic Brougham weighed 3780 pounds WITHOUT me in it according to the certified truck scale. Same as a V6 Challenger. Unpadded, unoptioned chevies weigh significantly less than a loaded Olds or Buick. We love our Challenger GT, best car we have owned by far, even better than our Rocket powered Oldsmobile's.False! My fully loaded 84 SS was 3,371 lbs. (at the dump without me in it), which makes it over 1000 lbs. lighter than the Challenger. My Scat Pack Charger weighed 4,440 lbs (At the dump without me in it). I believe the challengers depending on how they are optioned are a little bit lighter. I had a Challenger Core a few years back, just like this, 6 speed, cloth seats, no options, and it still came in at 4200 lbs. (the Core used to be the light weight track model SRT). With my new drivetrain, L29, iron block, Iron heads, Iron water pump, gigantic intake manifold, huge truck accessories, a 4L80E, with the factory bar and plate auxillary cooler, and a stock brass radiator, my car now weighs 3760. Before I even do any weight reduction, I am still at a 600 lb. advantage over a hellcat, which will matter once boost is added.
Having said that, it is a spectacular car.
Major Mike gonna step in and shut er down!
