delreyss said:del rey california.. its real close to fresno ca. does any one have any g bodys on 24 irocs pics
tonchis97 said:i have 22 asantis on my cutlass and i had to cut just to clear the 22s and they still cut alittle when the car dips
Qdub24 said:delreyss said:del rey california.. its real close to fresno ca. does any one have any g bodys on 24 irocs pics
There are a lot of 'em in the Customs Picture Gallery: viewtopic.php?f=41&t=6854
Did you replace all of your old springs and shocks with new ones? What size tires are you using? You shouldn't be having any issues with 22s unless they're over 10" wide.
82cutlass said:So Qdub...22 should tuck with no mods, no cut no rub?
Qdub24 said:82cutlass said:So Qdub...22 should tuck with no mods, no cut no rub?
If you buy the wheels with the correct offset, wheels less than 10" wide, and tires no bigger than a 255/35/22 then you should be fine. You should also replace your springs and shocks with OE replacements at a minimum when upgrading to bigger wheels. After 20+ years, you car's suspension is probably sagging and not even sitting at stock height anymore.
tonchis97 said:I Have like super skinnies on the 22s but the only thing I replaced was the shocks not the springs
