3.8 to 305 engine swap transmission question
Colindunn
31
Currently have a Saginaw 4 speed out of the Camaro in my 1978 regal and it is bolted up to the 3.8. Do I need to do anything when I swap the 305 in or should it all line up and bolt up?
Nope. Should be standard 10 spline. Don't forget the pilot bushing in the new engine.
What about the driveshaft and the rest of the driveline. Does anything need to be changed there?
Nothing behind the bellhousing should need to be changed as long as you are using the factory engine mount location.
pm sent
