3.8l
Then LS it is. Anything stock looking, 2bbl and crappy factory exhaust mean no performance, don't bother if that is the criteria. So no 4bbl and intake off a factory 4.1 V6 RWD? I believe they were 81 to 85, CCC and EGR. Your factory ECM should run it no problem. I would start with a 2004R and upgrade the gears to 3.42 plus.
Even with LS swaps, only the expensive Erod crate engines from GM are legal to swap in for CA as they come with the proper paperwork. Used normal production LS engines from junkyards are not easily legal to swap in due to the complex OBD2 emissions that must be completely swapped over intact in CA. That includes the gas tank and dash, plus no computer tuning as that is considered tampering.
He may be able to use the 85 only SEFI FWD fuel injection set up on his 3.8. A few more hp and torque. Add a 2004R and 3.42 or better gears. That will make it faster and better on fuel. Either that or cringe, a LS being California.
This is what I plan on doing for the time being. I think the quickest/least headache way to at least get a little better performance is a 200-4R swap and gearing. Anything else opens up a can of worms in CA in terms of referees, testing, approval, etc.
Power cost money and it seems like the smaller the CI engine, the more coin it will cost to achieve that extra power gain. i'm a 3.8 fanatic, turbo charged or naturally aspirated, my love is the same. A truly simple way to gain perhaps 20 to 25 HP would be truly simple and cheaply obtainable by these two methods ill share here. First acquire a 4.1 V6 Buick aluminum intake, these take a four barrel carburetor. Second, install a duel exhaust system used on the 83/84 H/O's. These two things within itself will wake that thing up enough to notice a big difference, and should be obtainable for under $500 if you play your cards right. I know 20 to 25 HP doesn't sound incredible, but when your applying this to a 110 HP power plant, this is a net gain of 25% increase! Good luck!
Reactions: Cookiekid
.....still 7.9:1 compression....
19.0 now that's gettin it
Reactions: fleming442
