It revs smooth and it has serious torque like it should. Yes, it was very frustrating.
I sold auto parts in the early 90's. BWD was good stuff back then. No more. I gave up on them close to 10 years ago. It's a shame.Well after the truck just running shitty after the head swap, I found 2 issues. First it was running on 7 cylinders, number 8 had a wire off on the injector. Noticable miss, I guees so. Second is the reason the truck has run shitty on and off. I "upgraded" to a brass BWD cap, some upgrade. It never sat on the motor properly, wouldn't tighten down, pretty sure it was moving, causing shitty running. It got really bad barely running, I had a Champion cap, brand new. I found the rotor with the spring broken off. This cap tightened down all the way and replaced the rotor. No more bad missing or violent shaking in reverse. Finally!
Really glad you found it. I had read in a few threads how frustrated you were and felt your pain. I think many of us have been there. I know I have.I agree, BWD used to be quality stuff, most products I have had good luck. I couldn't get any brass contact caps locally except the BWD and basically it was old stock. The Champion is aluminum like AC Delco but at least it tightens down properly. I am pretty sure this cap was the reason for the on and off poor running.
