- May 12, 2023
- 27
- 31
- 13
Yes, agree on the Compression Ratio and Heads. As I wrote earlier on this Thread, I plan to Extrusion Hone both the Exhaust Manifolds, and even in stock Aluminum intake manifold. I will replace the cylinder heads with Edelbrock Aluminum cylinder heads. And I will bump up the Compression Ratio to 9.5:1. And yes, a hotter camshaft as well.Problem is you have at best 8.5 to 1, restrictive heads and very restrictive exhaust. A chassis dyno would be handy for a starting and where it ends up after mods. Extrude hone and hand port the openings on the exhaust manifolds. The largest crossover, maybe a 2.25" versus 2" or at least mandrel bent and maybe a 3" down pipe and into either a custom, Hooker or Pypes 2.5" catback to remain visual and emissions complaint. Internally milled 5A heads with 350's valves and porting, a hotter cam would get you a nice boost. The dyno before and after would tell you how much.
I have a high-flow Magnaflow Catalytic Converter, which is less restrictive than stock. I also have the Pypes mufflers, which flow better than stock. And the Pypes tubing has a larger diameter than stock.
I will also try to do a before and after dyno run.
