gs dewd said:
DrRansom442 said:
gs dewd said:
As far as swaping from an olds motor to a chevy motor it is not nearly as complicated as people make it out to be and is really cheap to do. Hell if you have a complete motor all you have to buy is $20 worth of motor mounts, which your motor mounts probably need changing any way and the chevy mounts are cheaper then the olds mounts, and your done. Then just move the battery tray to the other side of the car and adjust some wiring. The fuel lines are on the right side with the 260's. Radiators are the same between v-8 olds and v-8 chev g-bodies. It's not like putting a ford motor in one.
Yes, engine swaps are always this easy ... just change the mounts and move the battery
Costs associated with building an Olds are absorbed by the parts needed for the swap and you know the Olds is a direct fit.
Actually I wouldn't even consider this an Engine "swap" as it is a direct bolt in that doesn't cost crap to do. I am still trying to figure out why people keep saying it's cheaper to stick with and build and olds motor. I am building my car on a extreme budget and I did my homework. It is going to cost me a little more then half as much to build and install a chev motor then build a olds motor. First you have to find a motor. Finding an old motor for cheap to build is not easy. I just bought a 71' vette 350 4 bolt for $200.00. I'll have roughly $2000.00 in it And with the $20.00 motor mounts it's a done deal. I already have a built 350 th trans and some of our cars came with the multi case trans so that is no prob on some. An engine swap would be like putting a ford or chrys. motor in our cars. A chev motor is a bolt in. It's just like putting a sm blk in a omega or a ventura same deal.
We can compare notes when done but my SBO build is half your Chevy ... even my core was cheaper. Now who is going to have an easier time fitting it in the framerails? I can reuse the starter, waterpump, all accessories .... as a matter of fact - I am. An Olds can be built on an "extreme budget" it's done all the time and when it's said and done I still have an
Olds. You'd have had an easier and cheaper time starting with a Monte Carlo.
