I have been working on my 1987 El Camino for about 4 years now. It is a complete frame up restomod project that has had its fair share of set backs. One of the many set backs has been the rear disc brake conversion. We are currently using a Stainless Steel (thats the company) conversion kit from Summit racing. However, due to the fact that we are also air bagging the suspension, and lowering the car, we are running into some serious clearance issues with the emegency brake mechanism when the kit is installed (per the instructions) with the calipers to the front of the rotor. The e-brake mechanism overlaps the rubber bump stop on the stock axle and subsequently the frame when the car is lowered. When we place the rotor to the rear of the caliper, the mechanism hits the bottom half of the shock in the stock location.
As this is my first disc brake conversion, im not sure if these clearance issues are normal and I just have to modify parts in order to lower the car, or is this a major manufacturing issue with the conversion kit. Does anyone know of a conversion kit that does not have these issues? I have never seen an El Camino with 4 wheel disc and this may the very reason why.
