have you checked to see what that Pontiac engine is, besides being a 400
http://www.yearone.com/updatedsinglepag ... ngid1.html
pontiacgp said:have you checked to see what that Pontiac engine is, besides being a 400
7cutlass9 said:all i know is its a 400 out of a 72 trans am
Bonnewagon said:I had a 1970 GTO 400 in my 81' Malibu wagon and it hauled *ss. I used 301 mounts and perches, had to drill new frame holes for them, but it fit perfectly like it belonged there. A 72' block has 5 mounting holes per side so it will bolt right in to the 301 mounts. A 72' is low compression and no EGR. An HEI will swap right in. Stock exhaust manifolds will fit our frames easily. Post the 2 letter engine code and let's see what it is. It is located on the front of the block just below the pass side head. Also verify it's a 72' either by date code or it should be cast in by the distributor hole. 400 should be cast into the side of the block near the freeze plugs. Even a low performance station wagon 400 motor will propel your car like rocketship.
RegalBegal said:G-Body_Vet said:It would be easier to set an Olds 350 back down on the 260 mounts and be done with it. Don't get me wrong, I'm Pontiac biased but an Olds for an Olds swap doesn't get any easier.
I agree with G-Body_Vet. But for the sake of argument, what is this going into? I personally like to see division engines in their respective division cars. Call me VERY old school.
G-Body_Vet said:The TH350 will bolt up to the 455. If you plan on thrashing the car the trans won't live long behind that much torque though.
