400 SBC question!!
disorder_in_dminor
13
www.myspace.com
Im pretty sure my 400 is externally balanced by the harmonic balancer and the flex plate, my flex plate is getting really shitty and i need to put my new flex plate (the one off my blown up 334 {305,400 crank) onto the car. When i stroked my 305 I bought the flexplate and it barely seen any use but i noted it had counter weights and stuff on them.
So i guess my question is everytime i change the flexplate on a 400 do i have to get the rotating assembly balanced????
No need to rebalance it so long as it was originally balanced for a 400 crank. It uses a standard imbalance weight, like a SBF, so the external parts are standardized.
all cranks which use a one-piece seal require a counterweighted flywheel for proper engine balance....with a two seal it's always internally balanced...
Well, no. The 400 is the exception to this rule. The 400 crank is externally balanced while the :262,265,267, 283, 302, 305, 307, 327, and 350 are all internally balanced with neutral balance flywheels.
