the Olds 403 is identical to all other small block olds engines externally, there was never a pontiac 403...
BBCCARGUY said:Hey all.... As for the 403 it has the same crank as the 350 so finding nodular cranks wont be so bad I have twisted the 350 pretty high in the rpm band and had really good luck the 403 would be good for street driving and having alot of power on the pump and not needing very steep gears, if you plan on twisting them to the 6,000 rpm range for longer time frames you should look into restriction kits to keep oil to the rods and the upper componants.
correctBlake442 said:From what I've come across, The Olds 403's were in the auto cars, and the Pontiac 400's were in the 4 speed cars.
