ksmitty said:I noticed your alternator was moved on the 1st pick and was curious how you did it. Did you have anything done to your heads or are they right out of the box? I believe where I have the eddlebrock performer rpm intake manifold they will bolt right up. I know they say they are for 403 and 455 but I was told they will work with my small block if I use an electric fuel pump. As far as my body work I have a OEM passenger quarter panel/ rocker panel/ 2 doors from Texas to get put on. The drivers side quarter panel and rocker panel have already been installed from the previous owner. Wish he had put both sides on at the same time so I didn't have to deal with it.Trying to find a guy in my area thats reasonable has been tough and so far no luck. I'm no body guy and have never painted. trying to find a guy who works out of his garage or something like that. Shop prices with there overhead is more than I can afford right now. Do you know anyone in the south west suburbs of Chicago like that? I also notice you run a holly carb. Did you ever try eddelbrock carbs> I have a Holly 750 cfm that needs rebuilding but bolted up the eddelbrock as it was on the engine and I didn't have to mess with it to get it to run.
No I left the edels "stock" for now... but they are designed for a big block 425-455 not a 403-350 small block, you can use them but the fuel isn't the issue, the combustion chamber is too big. You would need to take the heads to a machine shop and have them deck them to bring the chamber CCs down to small block specs! I had an edelbrock carb on my 307 and loved it, still have it and intend to use it on my moms 350 olds in her '73 88 royale, I also have a 750 edel on my '72boattail Riviera. I like edel carbs for their drivability and out of the box peformance but IMHO you will always be able to tune for more power with a holly based unit, thats why I went with a 830cfm Quickfuel technologies carb(basicaly a aluminum dressed holly). As far as the bodywork stuff goes, if you were in western Pa I could point you in a good direction(namely mine!
