Installed a 4L80E transmission in my 87 GN. I want to retain the factory 4 speed auto floor shifter.
The mounting bracket makes the cable do a tight bend due being mounted more rearward. This all starts due to the shifter shaft being not in the stock location from the original 200.
I'm sure something can be cobbled up here but it's also the linkage to the steering column that is different. The 200 had the shifter shaft in line with the bracket from the opposite side, with the 4L80E shifter shaft is back more.
If you've successfully pulled off this swap with the OEM floor shift. Share some pics, details and ideas.
