Yeah the LQ4 is the 6.0. I think the HP difference is probably something like 40hp above the 5.3 but it may be different. The only downfall the 6.0's have is that they are kind of hard to come by compared to 5.3's, and that they are a pretty low compression engine. The LQ9 is the upgraded version of the 6.0, with different dish pistons for a little bit of a compression bump. I read that an internally stock LQ4 with an untouched set of 243 heads, the compression will be around 10.2:1. Good enough for me at least. The 243 heads flow the same numbers as the 317 6.0 heads, just with smaller cc's. The 317 heads are great if you want to run nitrous or some boost.
Lots of great information here www.ls1tech.com, just have to sift through the F-body specific threads.
