6 AN or 8 AN?
ham1974
240
66
I am getting ready to mount tank and run fuel lines. I have some 6AN hose and fittings. I am going to use the stock fuel tank and looking at the lines coming out it’s going to be a PITA to get it over the fuel supply line. My question is 6 an good enough for a 400 hp engine? I can get 8 an but it’s pretty expensive and already have the 6. The car will be a cruiser but may hit the local strip a time or two.
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
6an is 3/8" and the fuel line in a stock Gbody is 5/16" so you won't have any problems feeding your engine. When I changed the lines in my GP I put the connection point for the tank in front of the tank so if I have to remove the tank it's easy to removed the lines and then drop the tank.
565bbchevy
9,618
12,701
Michigan
What kind of fuel pump and where is it located?
bracketchev1221
1,419
1,662
#6 and a 110 pump is fine. Maybe add in a lightweight pushrod too for the pump. I had 3/8 steel line with a Holley 110 pump in my nova with 10:1 355, 195 afr heads and a .535/.550 hydraulic roller.
