well if the 330 has the stock intake it wont have a provision to screw a temp sending unit for the CCC, making the CCC useless if not everything connected to it isnt connected to what it needs to make decisions. he never mentioned an intake swap.
and pray tell how is he going to set the timing if the CCC wont work right because of possible missing temp sending unit mentioned above? and why bother setting the timing with the CCC crap only to take it out and put another NON CCC distributor in? seems to me he can set timing then, what say you?
CCC distributors dont work right if the brain running it isnt working right either. little things like a missing sending unit can make it go to default and it runs like crap.
so if he didnt do an intake swap then he cant put a sending unit into the water passage. arent the brains usually programmed to operate with a specific cam profile anyway? seems to me GM did that whole cam CPU matching system when they built these cars. oh sure it might still operate but not very well.
and riddle me this batman, what's the pointing of using the CCC stuff on an engine that doesnt need it to run to begin with? that's like pulling a plug wire on your 500 HP engine. sure it'll run but like sh*t.
