youngwhip said:i dnt have a tach but i can get a timing light to check timing....but when i turn it down until it stop running and turn it up 1/4 of a turn, it ran pretty good. so i took it down the road but it was kinded running a lot slower then before...is that normal to? if so then why?
Adjust the timing. To do that, you will need a tach. You can get a hand held tach/dwell meter for pretty cheap. What carb and what type of distributor are you using?
