68 Pontiac 350 for the Safari
That's a healthy sounding engine in there. Watch that mechanical fan...you might want to put a shroud over it.
Yeah, that power steering is screeching a bit. Check your belt first, then the PS pump. I don't know if bleeding the system will help.
Sounds great! Plus it's a Pontiac in a Pontiac. :mrgreen:
Got the power steering fixed. The belt was only looped around the water pump. I found one that looped around the crank and water pump. problem solved 8)
It was squeaking a bit. Found that noise to be the u-joints. Replaced with another drive shaft I had, and bam! Another problem fixed.
