69 chevelle pedal assembly
So stick to modding my chevelle pedal to fit my cutlass bracket?
I used the bolt and bushings from the F body pedal housing in the G body housing to install the F body pedal. There is no bracket the way I did it to have a micro switch to kill the starter unless the clutch pedal is pushed cause that put pressure on the thrust bearing on start up which IMO is a bad idea.
Im not worried bout a starter cutout as I'd actually prefer to be able to start in gear
Reactions: pontiacgp
