i scored a real nice combo 383/7004r..anything out of the ordinary to expect from the install, i do have the proper driveshaft..i,m guessing the crossmember as well?..any clearance or fitment issues?
thanx
thanx
vonclod said:i scored a real nice combo 383/7004r..anything out of the ordinary to expect from the install, i do have the proper driveshaft..i,m guessing the crossmember as well?..any clearance or fitment issues?
thanx
vonclod said:if not i have a 7.6 rear out of a ss monty with 3.73s and it has a brand new auburn unit..
awsome info man, good to know that kinda stuff..is a 3.23 better suited?CWPottenger said:vonclod said:if not i have a 7.6 rear out of a ss monty with 3.73s and it has a brand new auburn unit..
Just a note 700R4 does not need a shorter gear ratio like a TH350 to get out of the hole. With a 3:73 rear end 1st gear will soar the rpm's like a ballistic missile. Just watch the rpm's and don't miss your shift.
thanx man, i cant wait to get it in, probably be a few weeksGBoDYon4s said:yessir thats an awesome combo,that'll give the regal a good kick in the pants...good luck
I think 3.23 or 3.42 would be optimal. General rule of thumb for a street car is to aim for a 10:1 compound first. 700R4 has 3.06.vonclod said:awsome info man, good to know that kinda stuff..is a 3.23 better suited?CWPottenger said:vonclod said:if not i have a 7.6 rear out of a ss monty with 3.73s and it has a brand new auburn unit..
thanx
what kind of electronic sender r u using for your speedo? I am running a 700r4 also and my cable melted on the headers. I do have the OE cluster set up. BTW my car has a 4.10 behind the 700r4 you should see mine wind up!!!CWPottenger said:vonclod said:i scored a real nice combo 383/7004r..anything out of the ordinary to expect from the install, i do have the proper driveshaft..i,m guessing the crossmember as well?..any clearance or fitment issues?
thanx
Cross member is different. I put mine in a Regal( not sure on other models) and the bellhousing was tight/touching the firewall lip seam in a couple places. I just rolled the edge of it for clearance. I also had a tight fitment of my speedo drive, but when I switched to electric sender it was fine. I also have a custom torque brace from rear end to trans snout that requires bolts in place before I put the rear of trans up in tunnel. I also used flex braided hose for the trans fluid lines for easier access and routing.
