72 plymouth valiant
zeth hale
zeth hale
227
187
clare, Michigan
#41
Wow a 55 nice!!
If you go with an Lt style engine you can change the cam on the fuel pump to increase the flow and pressure.
They make the kits for the V8 version don't see why it wouldn't work for the V6
I've talked to a couple guys that are making decent power out of the LT you basically get to a point where you convert to port injection while in boost. Even with larger cam and lt4 pump (supercharged engine di pump) unfortunately there's no good way to keep DI and run a 4l80e trans or really a manual 4 speed for that matter but I'll cross that road later. im still way up in the air on what engine it's gunna have but as you seen I have ALOT of work between now and then.
TURNA
TURNA
6,969
9,151
Socialist NY
#43
What are you going to use for a radiator?
And when are you going to get back on that wagon!!!!!!!!!
zeth hale
zeth hale
227
187
clare, Michigan
#44
Got a cheapo eBay aluminum radiator. Will be back on the regal once snow flies here. Have more time when it gets cold
zeth hale
zeth hale
227
187
clare, Michigan
#45
Modify the Jeep tank and sender to run a walbro 450
zeth hale
zeth hale
227
187
clare, Michigan
#46
Talk a little bit about some possible changes to the regal wagon build in this vid as well
TURNA
TURNA
6,969
9,151
Socialist NY
#49
Looks like an awesome time!!
Longroof79
Longroof79
9,837
5,531
Gainesville, Fl
#50
Looks like it was a cool event. It's nice to see a variety of different engine swaps.
Thanks for sharing the video.
