78-81 cutlass/monte carlo wheelbase 108 ?
27race
n00b
Jan 16, 2010
does anyone know if the wheelbase on the 78 79 A/G body cars is shorter than the 82to 88 G body frames
I know the spindle and hubs are different. sae lug nut studs not metric and outer wheel bearing different but are
A-frames and control arms the same? please advise if you have any info thanks.
supercrackerbox
385
2
Lincoln NE
108 sounds right. Everything should interchange. I know some of the front brake components are '78 specific, but if you keep everything together it should work.
Blake442
6,864
1,997
Minneapolis
All G-body coupes, sedans, and wagons share a 108.1" wheelbase.
'78 only used a different spindle with a smaller outer wheel bearing and hub size. '79-'87 are the same.
Every other part from '78-'87 should interchange with no problems.
