BUILD THREAD 78 Malibu "#DtoxBu/Caged Beast"
Bumpin1ohmSS
1,643
Cali to Az
Wassup yall! 80z back at it again with a 78 Mali. Picked it up last year from a club member and quickly began cleaning up parts and stocking up goodies for the build. Few pics of her as she sits. In need of some serious tlc and 80z is ready to handle the job...
She already has a few cosmetic mods done-tucked bumpers, updated front clip and I believe the rear tails are the newer style. Ive already started stacking parts up, cleaning and painting up stuff as I get em. A few parts I have so far are:
Front suspension setup:
Front upper and lower arms have been cleaned up, powder coated and new Spohn bushings, super travel ball joints and lower heavy duty ball joints.All new mounting hardware-nuts and bolts all from Spohn, SC&C front triangular jounce bar setup, Spohn front steering and UMI front swaybar and aluminum swaybar mounts. OPG 1" drop springs and Belltech nitro drop shocks, rebuilt steering box and jeep sfaft setup.
Rear Suspension:
OPG 1" drop springs and Airlift coil spring bags. Belltech nitro drop shocks, Speedway rear upper/lower trailing arm kit, Edelbrock antihop bars and a UMI rear drag bar(Pre order-waiting on shipment)
Rear end setup
Built Posi/373 7.5 rear with Maro SS rear disc swap, LPW rear cover and brace kit, Moser 26 spline axles
Brake setup for the front and rear:
Camaro SS caliper swap with blazer spindles, new hubs, Kore3 big brake kit and z51 PAB setup for 13.39" front rotors(black cross drilled) Rear setup is from a 2002 Camaro (LS1 rear brake swap mod) 12" black rotors, shock relocater brackets fabbed up and Im in the process of making some brackets for the e brake.
Motor will be a "357" rebuild. I have a new hydraulic flat tappet cam/lifter set, 670 CFM Street avenger carb, airgap style intake, new dizzy, fuel pump, Crane 1.5 roller rockers, GM serpentine(fresh powder coat done), new alt, new water pump(GMPP), new 4 core radiator and fan assy and all the needed stuff to get the motor goin.. Trans is a 200r4 that was built by the previous owner but will be torn apart and rebuilt-new 200 deep pan from hughs.
Whew! Nuff talk..Pic time!!!!
UPDATED 3-25-15
Looks like all my pics were lost somehow on flickr.
Bumpin1ohmSS
1,643
Cali to Az
7.5 posi rear end clean up... Picked it up for dirt cheap and it already had the swap done. Just needed that "EKCO" Warren treatment
Started knocking off a lot of the grime and stuff with a small chisel. Drained the fluid and broke out the wire wheel
Got it pretty clean
Bumpin1ohmSS
1,643
Cali to Az
Used some Eastwood "Xtreme Chassis Black" primer here..
I welded up the LPW brace kit and picked up some black drilled 12" rotors-Shout out to big Josh!!! Lowproelco
Fabbed up some shock relocation brackets
Decided to add a lil flare to the brackets...
Lil red to add some detail
Continued...
Bumpin1ohmSS
1,643
Cali to Az
With the rear clean up pretty much done,(just waiting on moeser axles) I turned my attention to my front suspesion cleanup(parts). I degreased and took the parts to work and sandblasted before taking to have the bushings pressed out. Its my thought that clean parts make the guys working on your shiz want to do a better job at installing and handling your parts...
Spohn bushings, steering, super travel upper ball joints and heavy duty lowers
powder Coated and bushings pressed in
SC&c bar. Prob will powder coat it red
new hardware
UMI front sway, aluminum mounts and QA1's
I had all the parts re powder coated and added a "Smoke" effect. They basically took some burning rubber and let the smoke from it set in while the powder coat dried. then Cleared over it. Cool effect.
With the front suspension pretty much done, i started in on the LS1 front brake swap: cleaned up the calipers, powder coated the blazer spindles, Kore 3 z51 pabs, new rotors ect
Continued
Bumpin1ohmSS
1,643
Cali to Az
cleaned up the front calipers and had the blazer spindles powder coated
After i blasted em.
VHT Primer and caliper paint
rear
kore3 pab's and powder coating the blazer spindles
Waiting on hubs and black x drilled rotors 13.39", turned my attention to the wheel wells (which i passed over to Saint for project Tummy Tuck) Since I wont be using the factory bottles and mounting locations on the wells, i filed down and filled in any holes not needed for a cleaner look (wellz by Warren stylez)
dry sanded to 800 grit. sprayed some sandable primer and wet sanded to 1500 grit
painted em with rusto engine block paint
Sprayed underneath with 3m rubber undercoat
With that done I did some cleanup on my dash out my Monte SS that been moved over to this project...
Bumpin1ohmSS
1,643
Cali to Az
Mel snatched me a floor shift steering column from a monte ss. I cleaned it and SEM painted it up. (landau black) Steadfast column cover to be installed soon..
Paint was still wet in these pics. It dried up to a nice oem sheen. Pretty happy with the outcome..
ss dash clean up
radio flip
reinforcing the rear radio section with epoxy to srengthen it up and drill out the mounts for the "flip" cage
adhesion promoter and then paint
this has my SS triple gauge setup from GSI interiors. i have a dual setup with digi gauges (trans temp motor oil temp) for this dash now..The radio flip is a good look
Massaged it for a nice fit. A lot of time went into this. cut chop and rebuilding the bezel/trim piece
Dakota digi panel also:cool2:
I had the dash re wrapped. Its just a $300 wrap but gets the job done. Black with silver double stitch
With some of the goodies installed/mocked up..
continued....
Bumpin1ohmSS
1,643
Cali to Az
Big Saint just swung thru and picked up the wells and i got his og set. Imma start on these later on today and will post up pics along the way.Did a lil more work on my e-brake brackets Im trying to setup. Simple piece of angle iron. I made a template, mocked it up on the rear and then transferred it over to the angle iron. I cut it to size and drilled the holes for the stock g body e brake cables to go thru. The clip has these lil prongs that hold the clip in place once pushed thru the hole. i basically re created what the old factory backing plate for the drum setup did. The angle iron was a lil thick and i had to mill down a few thousands of metal so the prongs would push thru. Im new to doin all this and using tools like this so bare with me. I must say it is VERY fun work tho. Im really enjoying learning how to fabricate and use the old noodle to problem solve. Also had a cool lil vist from josh "lowproelco". He dropped off some radiator core to firewall bars for my project! Thanks fam!!! "Tha Alibu" is moving right along!
Few pics
Here's what I started with. i had a chance to see a stock bracket from a donor 98-2002 Camaro, and did a quick google search to see if anyone else had come up with an idea for the e-brake lever. Found a nice pic and tried my hand at making it...
Making the template..
I used a spray can top to make the pie cutout. Then placed the cutout up against the back of the rear end backing plate flange and pressed the cardboard to make the the holes for the backing plate bolt holes
Template looks decent..I just flipped it backwards to make up the op side bracket(mirror image)
Mock up to get and idea of how it works and looks...
I also measured where I'd want the stock e brake cable to "clip in" just before the e brake "lever" on the Camaro backing plate. I have it slotted on this template, but didnt do it this way on the final setup. I basically did what the stock G body backing plate did-cut a hole for the cable to clip into and allow the prongs to snap up against the back of the bracket..
Cut the pieces to length..
[youtube]-zO8fk9iwtE[/youtube]
Drilled the holes out and mocked it up on the backing plate. Ive figured out a cleaner way to do it. bare with me as this is my first attempt at doing this kind of stuff..
After I cut the "half moon" out I sand blasted the bracket and then started trimming awaysections not needed to "clean it up" some..You can see that I trimmed away some material so the bracket clears the rubber boot on the backing plate's ebrake lever area..
I measured the stock G body clip and (9/16") and eye balled the center of the bottom section where the clip will run thru. I marked it and used a 9/16" drill bit to make the hole. Well I stepped the bit sizes up and stopped at 9/16".Took the homegrown "brackets" to the garage shop and mocked em up..
At this point Im pretty happy with the setup and how its coming along. I'm thinking to myself that even if this doesn't workout, I'm learning how to figure out stuff(problem solving) and learning how to use different tools. As my boy at work says "Now you hot rod'n son!!!" LOL
The thickness of the angle iron was a lil too thick for the stock ebrake cable clip to push all the way thru the 9/16" hole on my new bracket. I couldnt get the prong clip to seat into place. This is where things got really fun. I figured out how to use a caliper to measure the thickness of the angle iron. I then came up with an amount I wanted to "shave/mill" off around the front of the 9/16" hole in the bracket. I figured I could let the ring around the clip (just before the prongs) sit down inside the milled out area. This would allow the prongs to get the needed clearance to sit inside the bracket correctly as it did on the stock GM drum backing plate. I also measured the small amount in between the prongs and clip ring.. Then I milled it out. Measure twice and mill once!!!
[youtube]P8MjhKjWh9E[/youtube]
Not the best, but for my first time doin stuff like this it will work. Ive already figured out a much better way to get it going the next time I get a chance to work in the machine shop..
I sprayed em up black (I'll powder coat em later) just to get a "feel" for how they will look. You can see in the pics above that I rounded the sharp edges off trying to "clean" it up a bit.. I just used a grinding wheel, belt sander and then wire wheel..
Top view. I also used longer 3/8" grade 8 bolts (fine thread), washer, lock washer and a nut with nyloc. The finer thread will give it more bite and the nyloc nut will prevent the nut from backing out due to vibration. A lil loc-tite will be added on the final setup...
You can see the hole I cut/milled out is in line with the e brake lever on the backing plate.
The next step is to either trim a little of the stock e brake cable's spring away and loop the covered wire back onto itself and use and u bolt clamp setup. (this will create an eyelet for the "Maro" backing plate ebrake lever). Or I can cut a section of the stock g body e brake cable out, cut a nice section of ebrake cable with the correct eyelet from the donor Camaro, and use the u bolt clamp to ment those two wires together. The ubolt setup is strong as fawk! We use em at work on elevatores and it will get the job done. The other thing is to completely remove the donor cars e brake cable and swap em. I'll see what I want to do later on. Im on a "Fab/mock up" hight right now. HAHA
Thanks for looking! I'll be working on my new to me wheel wells today when i wake up. Sorry for the loooooong post fellas..
Lowproelco
230
16
So Cal
ahh man ELCO WARREN doing it a third time around.. love that rear end bro.. makes me all tingley inside lol... if yall dont subscribe to this thread your missin out...
Peter
1,175
74
48
MA
man, awesome work
Bumpin1ohmSS
1,643
Cali to Az
Thanks FAM!!! Preciate you rolling thru and checkin out the projects and stuff. Also, thanks for the painting and mock up tips also bruh! I passed the just finished wells over to Saints "Tummy Tuck" project and have a "new to me" set. Let the fun begin!!!
My new UMI rear drag bar came in. I ordered it back on Nov 24,2012. It was a pre order deal and I knew it would be a lil wait. . Few pics...
rear drag bar, hardware and front bar-UMI
The project is coming together. Pushing to get her on the road by summer. Thanks for checkin her out. I'll update as I get stuff done on her. The car is in Arizona, and I go out there once a month..
Elco Warren
80! :twisted:
