Hello, all. I'm sorry if I ramble. I've got a '79 Century wagon with a tired 3.8 NA/TH350. I'm installing a 24,000 mile 1987 3.8 NA with a Monte SS 200-4R. The transmission swap is not an issue. I'm converting the '87 motor to a '79 so all the electrical and vacuum is plug and play into the '79 harness. I'm swapping the valve covers, exhaust manifolds, carburetor, distributor, and intake manifold from the '79 onto the '87. The '79 intake had two ports that were completely carbon-clogged...I believe them to be an exhaust crossover from #3 to #4. The ports on the '79 heads were also clogged. Here's the question: should I replace the intake manifold gasket with the '87 (fel-pro MS96037) which blocks these ports or the '79 gasket (which is the same as the '87 TURBO gasket, fel-pro MS96033)? I haven't pulled the '87 intake yet to look at the heads to see if there is even a port here or not. Are the heads that different between an '87 NA and an '87 Turbo? (I also have an '87 Regal Turbo T). Thanks for your input.
