For a long time, I had been planning on doing a 403 swap but now I've decided on a 425 instead for several reasons -- those reasons aren't really the point of this post. I've been trading emails with a guy about 3 hours away who has a '67 longblock with C heads, an intake (not Toro), oil pan, and filter adapter. I'm concerned with the best options to make it look like a factory install in a car that originally came with a 305.
-Would it be in my best interest to looks for an Olds powered donor car for all the supporting pieces? I know I'll need to get a driver's side battery, Olds motor mounts, accessories and brackets for an Olds, Olds spec AC compressor and hoses, wiring harness. Anything else?
-Would Olds W and Z exhaust manifolds fit without clearance problems?
-Will a Performer intake with a Qjet and stock air cleaner fit under the hood? Any other intakes that would be better on a stock 425?
-If I can't come up with the "correct" Quadrajet for an Olds 425, are there any other applications that seem to run good on the Olds? I have a Cadillac 425 carb but suspect it's probably calibrated pretty lean.
The engine I'm considering was supposed to be a runner when it was pulled so I'm not planning much more than a cleanup and reseal with rings, bearings, timing set, and head refresh. I'll likely reuse the cam if it looks fair. This car is 99% cruiser and won't be seeing strip duty. I plan to have my 200-4R upgraded to handle the added torque but will likely cross my fingers on the 7.5" and probably pick up some spares.
I welcome any input and suggestions. Thanks in advance.
