GRAND PRIX 79 Grand Prix Resurrection
CDUNIGAN1981
307
347
I had no idea the ports could be different.
Is a 6x head one or the other by chance?
Remflex Inc. 12-004 - Remflex Exhaust Header Gasket Sets
Remflex Inc. 12-001 - Remflex Exhaust Header Gasket Sets
Larger ImageLarger Image
BrandRemflex Inc.Remflex Inc.
Manufacturer's Part Number12-00412-001
Part TypeExhaust Header and Manifold GasketsExhaust Header and Manifold Gaskets
Product LineRemflex Exhaust Header Gasket SetsRemflex Exhaust Header Gasket Sets
Summit Racing Equipment Part NumberRFL-12-004RFL-12-001
Price$34.39$34.39
+ to Cart+ Cart+ Cart
Customer Rating(4)(9)
Highlight Different ValuesLess Information
DescriptionExhaust Header Gaskets, Graphite, D-shaped Center with Oval End Ports, Pontiac V8, PairExhaust Header Gaskets, Graphite, D-port, Pontiac V8, Pair
Gasket MaterialGraphiteGraphite
NotesD-shaped center with oval end ports. Suggested torque is 20 ft.-lbs.-
Port Height (in)1.940 in.1.813 in.
Port StyleD-portD-port
Port Width (in)1.500 in.1.375 in.
QuantitySold as a pair.Sold as a pair.
Thickness (in)0.125 in.0.125 in.
CDUNIGAN1981
307
347
I've decided to just pull the motor out.
In the end, it has been 20 years since it has gone in and now is a good time with transmission needed to come out anyway.
I gave it a long hard look yesterday... it has to happen
Pull Motor for good inspection.
Install new deep oil pan
Install angled oil adapter if it ends up being needed for header clearance
Install starter
AC Delete
degrease engine and paint
degrease engine bay
CDUNIGAN1981
307
347
I need to pull transmission and Motor.
I have the manual which I'm sure details how to do this but was curious what pointers could be offered.
The manual is not with me at the moment but I'm curious to see if it has one process to pull both at once.
This will be my first Motor pull and transmission drop....
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
My 0.02:
I've done it both ways. The biggest pain is dumping transmission fluid all over the place when the drivetrain is tilted. Find a trans yoke or yoke plug and duct tape that bad boy in place. Given the choice, I prefer to split the two pieces and remove them separately, but working on your back underneath is a challenge. Get a big cardboard box and a trans jack or some strong helpers and a big cardboard box to slide it out from under. Retain the torque converter with a tie-down strap or a couple big pieces of duct tape. full of fluid, it's heavy and messy when it lands. Other benefit to splitting is the engine will lift out with less risk of damage to 40 year old parts along the way.
  • Useful
CDUNIGAN1981
307
347
My 0.02:
Thank you for the response.
Just looked up 'yoke plug'.
Had no idea they existed
Easy $5 ante
Just ordered
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Sometimes the noblest purpose of one's life is to keep others from making a royal mess of theirs...
lilbowtie
3,460
3,965
Canton Mi
Depends on the situation, If I'm not doing anything to the trans I pull just the engine - much easier since I don't remove the radiator or even the hood. I've also found that If I'm pulling engine and trans it's easier for me to pull the front clip instead of trying pick it up a mile high w/ the distributor hitting the firewall (SBC) and the hassle of trying to get it in and out of the engine bay. Ditto the yoke plug
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
I guess I do sh*t the hard way. I pulled the bumper, header panel, and core support to get it all out at once. The little Harbor Freight trans jacks are helpful ,too.
pagrunt
9,167
15,346
Elderton, Pa
I did the current engine/transmission install on a naked frame. Even pulled the old engine off naked old frame from which made it easier for the jagoffs who stole the Saginaw with shifter to do so.
565bbchevy
9,614
12,683
Michigan
I have always pulled the BBC out of my Monte by itself from the side while in my garage with the Monte on jack stands so I have room to work underneath.
