8.8 Lower control arms
othtim
392
16
Hello. I just purchased a mustang 8.8 rear end. This rear end has existing mustang lower control arms. Can I re-use the mustang lower control arms or do I need to use the g-body lower control arms? or do I need aftermarket. I was planning on purchasing the UCA and bracket kit from baseline suspensions to correct the IC of the rear end.
I belive you should be able to use the g-body lower arms.
Anyone know what types of sway bar options I have with this swap? If I'm using adjustable lower control arms, where do I mount the sway bar? Any tips? I looked at some stuff from TRX, but I didn't really see anything that was lower control arms for a g-body 8.8 swap w/ sway bar brackets.
