What's up guys? I've got a 79 Monte with a stock 2002 Camaro LS1 and 4L60E (build: http://www.diabloformularacing.com/ls1_swap_2); it's only going to be a spirited daily driver for now. I'm planning on overhauling my suspension when I get back from the 'Stan in a few months and I've been doing a good bit of research but I can't find exactly what I want in reference to the 8.8 Ford rear end. I have a 7.5 now with airplane gears; I know I could upgrade it, but I'd rather invest the money in something stronger (whether I need it now or not). I also know I could get an 8.5, but they're relatively expensive and I'd still have used parts, so I've moved onto the 8.8 to lower the starting cost point. I understand I'd need to weld on the spring perches and I'd probably use the baseline kit (http://www.baselinesuspensions.com/kits/chevy.htm) for geometry issues-I know enough Marines with Mustangs and welding skills that should be able to help me out. What I need from the G-body community is which 8.8s work the best (I've heard explorer, mustang, t-birds, etc) with minimal modding and which years specifically? Any way I can get one that fits AND has the disc brake set-up? Any other outstanding issues and corresponding fixes with this swap (lug pattern)? If it matters, I'll most likely go with the SC&C Stage II Plus kit up front with OPG 2" lowering springs and Bilstein shocks all around. Still debating on lower control arms. Nothing is set in stone though, so let me hear your suggestions. As always-thanks for the help.
