Will 8 inch wide rear wheels work without tubbing? How much do they stick out past the wheel wells?
I plan to use BFG radial T/As 235/70 R15s what backspacing did you use?With the right backspace an 8" wheel will fit in the wheel wells, depending on tire choice.
Excellent.... I have the stock rear end in it. That's what I want.... looks great!I do not have 8" wheels on mine, but I have seen it done. I will leave this for someone with actual numbers, but a 235 should fit with an 8" wheel no problem, with the right backspace.
