The lifters falling out is a problem. You need to put the lifters back onto the lobe they came off from - it is critical. Otherwise you can expect a flat cam in a hurry and a complete rebuild will be needed in short order. The good news is that cams are cheap, less than $300. But those heads don't help much.
Your at a point where you need to decide to do it right or poke and hope. Doing it right isn't that hard with some basic tools and someone to gyuide you.
You really need to post what you want to do with this motor and what your budget is. If you ask, then I'll answer, and being that I'm somewhat new to this forum I don't know too many people here, but I would assume that there are many that can guide you through a basic cam
You really need to post what you want to do with this motor and what your budget is. If you ask, then I'll answer, and being that I'm somewhat new to this forum I don't know too many people here, but I would assume that there are many that can guide you through a basic cam and head swap. The tuning is much more difficult than the assembly IMO.
First item on the agenda is to inspect the bores above the pistons and drop the pan and check a couple of main and rod bearings to determine if the short block needs work (if it's a time bomb) presently.
Best of luck - Jim
Well to be honest when i bought that motor I had a friend come and we took the oil pan off and he inspected it and said it is good down there. Wouldn't let us remove the heads though.. Understandably. So I was buying that motor with the idea of clean and paint and drop it in. Possible do some work to the heads if its in the budget. The rest of my cash just went to a few minor upgrades plus transmission and rear end coming up next week. (Ate up a lot of cash there lol) As far as the lifters coming out I was told the new set I bought would be fine to use but trying To guess where the old ones go was a no go. My friend said people will actually put used cams in with new lifters and it's quite common. I'll really have to look into what you said before I put the heads on it and maybe I'll just buy a new cam.. We'll have to see. Thanks for the info though. But basically to answer your question my intentions/plans for this motor were/are to clean it up and make it look pretty and at the same time hopefully find the right deals on performance Parts to buy and bolt on it. I never found any heads that were in budget so most likely if I dknt get anything within the next 3 weeks than those 882's are gong back on. it is what it is k guess lol thanks again For tips!
