Hey all, my tach has a strange fault I've been trying to troubleshoot that's been happening since I got the car about 10 months ago. When I start the car the needle barely moves at all, we're talking maybe a millimeter or so. Strangely, If I turn on the parking lights or headlights the needle will move a tiny bit more. Then, if I rotate the interior light dimmer knob the tach needle will finally show some real movement. It maxes out at about 1000 RPM even when I'm revving around 2k or more. The V8 jumper in the back of the gauge cluster has been hard-soldered.
I'm guessing it's gotta either be a bad tach or a ground fault. My other gauges are working (though I think my fuel sending unit is bad), and I show good voltage on that gauge. I read somewhere about strange tach faults that can occur from bad headlight switches and the one I have now was swapped from a pick-n-pull so unless that one was bad as well that's not it.
It appears pin 2 on plug 2 is the ground so I'm going to try and see if it branches to everything else. There may be a fault just before the tach I'm guessing. I'm no engineer but I took electronics in the Navy and I know my way around a schematic and a multimeter so I'm hoping I can figure this out. I'd like to try hard wiring a ground wire directly to the tach to see if that helps, otherwise I'm afraid the tach itself is probably toast.
Incidentally, I also need to track down why my turn signals and high beam indicators aren't working on the dash. Wonder if the two are connected?
Any opinions would be welcome. Much thanks!
