83 olds 307 -battery tests good, alt off car tests good - no charge to batt in car what to look at?
J
jim83
34
8
title says it all. Batt & alt good, no charge to batt when in car - has factory gauges (ralley pack?) & that shows low volts
any ideas?
TURNA
TURNA
8,765
Socialist NY
put your meter on the bat and jiggle the wires
J
jim83
34
8
Where would be a good place to look for a bad ground?
Cables are clean & tight. Would the 2 wire plug on the alt be a possibility? Car only has 65 k on it & has never been molested or modified & has spent it's life in a rust free environment
Thanks for the suggestions- keep them coming!!!
Bonnewagon
Bonnewagon
6,312
Queens, NY
If the alt wire to batt goes down to a fusible link that may be shot. Try hooking a 10 gauge wire from alt + stud to battery + terminal. This is a generic diagram.
J
jim83
34
8
Alternator is a new not reman & was bench tested- good. Meanwhile if the fuseable link test bad by running the 10 wire . Where is the fusable link located?
I have the factory shop manuals, but they don't cover gauges only idiot lights.
Thanks again for any suggestions - they are helpful
MrSony
MrSony
4,965
Des Moines, Iowa
Fuseable link is in the hot wire that goes from the battery to the starter. Its a little black or grey pill shaped thing inline with the wire. They go bad. Hook a 10gauge wire from the stud on the alt to the batter as said above and see if it changes. If so link is bad.
J
jim83
34
8
Is the 10 ga wire from the stud on the alt to the batt + just a test or can I operate with it jumped that way for a day to chase parts
should I disconnect it when not running?
Thanks, you have been very helpful
