Re: 83 regal 3.8L timing chain broke and now it won't start
I'm starting to wonder if the cam lobes are bad or bent push rods? The motor only has 59k original mile on it tho...... PLEASE CAN SOMEONE HELP!!!!!! I put it at TDC on number one cylinder on compression stoke then rotated it one full turn back to zero then dropped the dist. In with rotor pointing at the number one plug wire on the cap which is roughly 9 or 10 o'clock position.....
