78-88 G-Body Pro Series Adj Control Arm Package 2
www.google.com
Deluxe 1978-88 Metric Chassis 9 Inch Ford Axle Bracket Kit
You can weld these brackets to your 9" Ford housing and install it in your GM Metric chassis. Includes upper and lower control arm mounts. Welding required. Designed for 3-1/2" axle tubes, but can be fit to 3" tubes. For use with an 11.75" diameter brake rotor. This Deluxe rear end bracket set...
www.speedwaymotors.com
Not sure if these links work correctly but these are the control arms I've been looking at and the mount kit for the 9". So other than the spring mounts that should get it mounted in the car?
