jae said:May I ask why everyone went off on a 200-4R tangent when his combination is SBC 350/TH350 and going to Olds 455/TH400?
Shouldn't there have been a mention of crossmember differences and choices, the electric kickdown switch that's going to be needed for the transmission, output shaft spline count, other possible issues going from Chevy to Olds? I know we're estatic about an Olds using big Olds power but let's not forget these important things. 🙂
You mean like this post from above?
joe_padavano said:Vern said:She is going to be fun now! Sorry I don't know the answers but can point you in some good directions in addition to what you should get here. www.oldspower.com and www.robertpowersmotorsports.com. Kooks makes a quality header for this. I remember reading something about useing the clamshell part of the 307 mount as its lower.
307s don't use "clamshell" mounts. There are metal brackets that bolt to the frame and rubber mounts that bolt to the engine. The metal frame brackets are the same on the 78-88 A/G body cars and the 77-90 B-body cars, so any of those are appropriate donors. The rubber mounts are readily available from any auto parts store. I just bought a pair for my Custom Cruiser from Advance Auto Parts for $8 each.
The TH400 should be a bolt-in since it uses the same crossmember location as the 200-4R that was stock in your Cutlass. The driveshaft will need to be shortened and you'll need the correct front yoke.
Since you don't have any 307 accessory brackets, you'll need to get appropriate Olds brackets. The 307 brackets are more common but require small modifications to fit the tall-deck 455. If you plan to use the original R4-style A/C compressor, you'll need to use the modified 307 brackets. If you don't plan to use A/C, just get the 68-76 Olds brackets, which fit both big and small blocks. Olds used three different water pump lengths, depending on whether you had A/C or not. Get the pump, brackets, and pulleys as a matched set.
Kooks headers are great but pricey. The 69-72 W/Z manifolds will also work.
Good luck.
