I might take you up on that depending on next round of troubleshooting.if you want i have a rebuilt 2 barrel computor controled carb that was working on a car last summer
The dwell meter comes in tomorrow. Shop manual should arrive tomorrow or Thursday too.it;s a dualjet came off a 82 el camino with a 229 6 cyl try to get yours running first did you put a dwell meter on her ? you could also put o volt meter on the 02 senser wire to see what the 02 senser sees high volts = rich the mixture control solenoid should get lean commands also i would check the map senser volts first google how to do that
