I'm installing a push start ignition switch I bought on Amazon
I have it wired correctly as far as getting it to turn over but I'm not getting gas to the engine...
Does anybody know of the function of the color coded wires on these black and blue ignition switch harnesses ?
I wired to the "ignition" (pink and orange), the "battery 12v" (red), and "starter solenoid" (purple)...turns over, but doesn't fire up ?
Is the fuel pump wire fused with the ignition wires (pink and orange), or does it have a wire of it's own ?
Also, I want to hook all of these things directly to the power source of the main on/off switch, so when I flip the main switch on, all of these things power on once I flip only the on/off switch, and all I have to do is hit the "engine start" button to start it up.
I want to use the accessory switches for other things later, if so...
